Question Motorola XPR 7350 / Repeater XPR 8400
Razores
Phillipines
Hello,
I want to add another channel in my Motorola XPR 7350 and connect it to my Motorola XPR 8400 Repeater to widen the signal. But I am having trouble when I'm setting up the XPR 7350 radios. What I did is I add another channel in my XPR 7350 radios and use the XPR 8400 Repeater's FREQUENCY but it doesn't work.
The radios is not transmitting to my repeater. Should my repeater's TX & RX LED would lit up if it works? I install Dynamic mix mode in my repeater so I could also use the analog mode. Can someone help me to set up the settings in my radio so I can add another channel to my radio using the repeaters frequency.
Thank You
