Question on ARC500 programming software
sparks40
Illinois
I was wondering if it is possible with this software to highlight and move more than one line at a time in the main screen and move them up or down to organize them. Thanks.
captclint
Mountaintop, PA
Yes. Simply put the cursor on the far left and highlight the 1st freq, and drag down to last, holding shift. Then cut. You need to insert that many blank lines in the group where you want to paste, and then paste. You can EDIT, Shift up or down.. You can also change the order of any column by double clicking on the header. I also do this to put freq in ascending order, which makes the scanner more efficient(faster scan).
sparks40
Illinois
Clint,
Thanks a million for the advice. The software manual doesn't do a very good job of explaining all the functions of it. This definately makes things a lot easier.
