Question on Non-Adjacent Site Search
So what happens if you have Non-Adjacent Site Search enabled vs disabled. With it disabled will the radio only look at the first control channel programmed and then if you are out of range of that control channel it won't look at the other control channels programmed in the trunked system? Say you have two control channel programmed in your radio with NASS disabled, you are out of range for the first one. You turn on your radio cold, will the radio only look at the first control channel programmed and not look at the second one?
Would like some clarity on what NASS is used for with an example.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
Disabled means the radio will use the adjacent site info sent over the control channel. Enabled means the radio will check the frequencies programmed into the control channel list in the radio. If you have a lot of CC's programmed it could take several seconds to "look" at all of them, causing you to miss traffic.
