DannyBoy2k
I've just been using my SDS100 around the house, but decided I'd like to have an antenna on the car for some mobile capability. I have a friend with a few K400 mounts that he highly recommended, so I thought I'd get one, but there seems to be a complete shortage of them right now. He had a K400C that he replaced the cable with the Diamond C213SNMO (essentially making the mount a K400SNMO) that he sold me. However, I had a question about the installation of the cable.
At the moment, the center pin doesn't stick up very far. There is currently a star washer between the underside of the mount hole and the cable/NMO pin. I wasn't sure if that was only used for a through-hole application or if it should also be used with the K400 mount. Without the washer, the center pin would certainly be higher, but I didn't know how much higher the center pin on NMO typically is. In the photos on the Diamond website for the K400SNMO, the center pin seems taller.
I called the Diamond technical support number on their website, but had to leave a name/number for a callback. If anyone has thoughts while I'm waiting for that, I'd appreciate it.
Thanks,
Dan
Thanks,
Dan
