Question on TRX-2 EZScan ScanList Alert Settings
Tattoooz
Foley, Alabama
Did a quick search and I didn't turn anything up on the Alert Settings on the Scanlist Tab in EZSCAN Software. I see the following options under "Alert" but I do not see anything in the manual concerning these.
The options are:
None (obvious)
Chirp
HiLo
Alert
Ring
2Chirp
HiLo Fast
LoHi Fast
MODAT
ST ST
XMIT
Engine51
5/6
G6
G7
G8
Are these different audio alerts?
Thanks,
Tattoooz
JD21960
ILL-annoyed
Yes. You can test them manually on the scanner while browsing any object* scroll to find "Alarm" and it will play each one while you use the arrows to advance them. EZScan batch edits can be done then after you pick the one you like. *hint* Engine 51 from the old TV series Emergency is best, but it's too long. It cuts off the first parts of transmissions. Chirps and beeps and boops are the best ones.
K9DAK
Wauconda, IL
Hmmm... wonder if there's a way to add / edit these like there is for the startup sound... Wendy?
