question.....please
Aircargo
North New Jersey
ihi....got my ic5100 set up. didnt put the x50 diamond up yet but using a tram mag mount sitting on roof,rubber roof. just sitting there using it for now. diamond x50a going up.... anyway....my scanner is sitting on my desk with a telascopic antenna on rear of radio. when i transmit on ham.....the scanner picks it up. screen on scanner says "found"....then u hear interferance....bc355n scanner. txs all.
KevinC
Other
Home
Are you transmitting in D-STAR? If so your scanner won't decode that.
jaspence
Michigan
You are risking damage to the IC-5100 transmitting with that antenna configuration. A mag mount needs a steel surface for proper impedance.
popnokick
Northeast PA
Because you are seeing the "Found" message on the scanner's screen it makes me think you have the scanner's Close Call feature turned on.
