question re, submitting a trunking table to the DB.
N9NRA
Hey there, i managed to ferret out the trunking table for a system that is comming online here in WI, and want to submit this to the DB for updating of the system`s DB entry (this is for the WISCOM system here in WI). How should i send this? I can send it in the format i copied it in from my scanner`s display, or i can try to reformat it (i don`t have Excel unfortunately, so no soap there). What`s your pleasure on this? Thanx! N9NRA
loumaag
Silent Key - Aug 2014
Katy, TX
Are you referring to the "band plan"?
If so, isn't being broadcast by the CCh's at the various sites?
In general, you can submit anything that you can put in an ASCII text file, it does not have to be formated; formatting just makes the transfer process (from your submission to the DB through the DB Admin's work) easier.
N9NRA
Yeah the bandplan is being sent out on the controls (control channels), but after i managed to find it i got to thinking that it might be a good idea to submit it, in case for some reason one would need to hand-program it. Thanx for the info. 73. N9NRA
