question regard minitors
fnnm1062
longtime member
Oakland County, MI
If I were to purchase a used Minitor fire pager would it be able to be programmed to decode DTMF, DCS, or 1000 Hz tone functions? I dont know much about programming radios, but wanted know if this was possible. Also would it be able to be programmed to recieve from a ham radio frequency in VHF Hight? THanks
rcvmo
Romulus, Mi.
It all depends on which minitor you purchase.
I just pitched a bunch of Minitor 1's, saved the 2's, and dont have anything beyond that.
2's , you'd have to change crystals, re-tune,-re-reed. Lots of work.
Not sure about the 3's on up, although I've heard they are programmable with tones as well.
rcvmo
N9JIG
Sheriff
Moderator
Far NW Valley
There are some Minitor models that had PL, I haven't seen one that has DPL (But that doesn't mean there wasn or isn't one)
I have never seen one that decodes DTMF, but again, that doesn't mean there isn't one.
As for the 1000 Hz., programmable Minitors should accept that as a valid tone. You may have to experiment how long the tone needs to be to open the receiver, usually 4 seconds or so is required.
