BCD996XT: Question Regarding 800 Mhz Band Plans
KB1OQA
Wayland, MA
I have a Uniden BCD996XT Scanner. Zones 3,4,5,6, and 8 of the MA State Police Motorola Trunked System have been programmed into it.
I am able to receive Zones 5 and 8 with no problems. When the MSP rebanded, these two zones were changed from an 800/900 Standard Band Plan to a Custom Band Plan. In checking the other Zones, the Band Plan for them show either an 800/900 Standard or a Splinter Band Plan. Currently, I'm not able to receive Zones 3,4, and 6.
My Question is: Since the Custom Band Plan is already in place for Zones 5 and 8, which I'm receiving fine, do I have to set up a custom band plan for those zones I can't receive, or just change the setting to Custom?
I'm using an outside antenna, so I it's my feeling that once the change(s) are made, I should be able to receive them no trouble.
Any thoughts appreciated.
cg
Connecticut
Rebanding is completed on the Mass SP system. You will hear everything if you use the custom rebanding bandplan.
chris
