Question regarding NX-800HK programming
30319
Atlanta GA
I have an NX-800HK. Where can I adjust the power setting?
I just deleted several channels a few minutes ago. I’m trying to write to the radio now. I’m getting an error message that says one or more errors have been detected in the following: Home CH/GID
How can I fix that please?
I’m using KPG-111D to program it.
Thanks for any help you can provide!
That means you have a button set for home channel, but you deleted the channel that was set for that.
As for adjusting power:
In the channel edit, select high or low.
But, per your earlier PM you sent me, the HK model will only go down to 10 watts output, and that's going to pull 8 amps. Your power supply is only rated to 5 amps output. When you try to transmit, it's going to overload the power supply. The power supply will either shut down, or the voltage is going to drop and the radio will restart.
Do ——NOT—— go into the service settings and start adjusting the low transmit power adjust trying to change this. The process for adjusting the power output of the transmitter requires many steps and the correct test equipment. Not following the entire procedure laid out on the service manual and not using the correct calibrated test equipment, can result in your radio going unstable.
You need to either get a power supply that will do more than 5 amps (I'd recommend at -least- 13 amps), or you need to get a non-H model radio that will do 5 watts on low power and only draw 5 amps.
30319
Atlanta GA
MMCKENNA---I promise not to touch the power settings as you suggested! I working on trying to locate what I believe I assigned the Home Channel to.
OK, just don't want to see you damage your radio. I've seen people do this, thinking they were doing the right thing.
Really, get an appropriate power supply and you'll solve the problem.
30319
Atlanta GA
Thank you so much for all your help as usual and your genuine concern! I sent you a PM. Again, thank you!
