Question regarding Tetra Recievers
Johannesburg, SA
Hello everyone, I am new to radios and have quite a limited knowledge so bear with me.
I am trying to help out a local police force figure out their tetra com system. Essentially they use a Cobham CH150-13 system but getting a hold of one is proving problematic. Are there alternatives to this receivers? Is tetra an exclusive system? Apologies again is some of these questions appear too basic for a specific forum such as this. Thanks in advance.
rmi2065
Riverside, CA
TETRA is a standards based radio system. And as such any manufacturers' equipment should be able to work with the infrastructure. I suppose the only concern would be gaining access to the system. I would speak with their system administrator. He would be able to tell you if they're using encryption. Be forewarned, ordering a radio with encryption (TEA1,2,3 or 4) is near impossible for a private party. It's not as easy as it is for P25 radios.
Johannesburg, SA
Gotcha and thank you, I forgot to mention as well that its actually a transceiver if that makes any difference.. So assuming its not encrypted would a similar unit with close to identical stats function in the same way and is it a straightforward process? I was told I had to wait over half a year to get my hands on that part otherwise hah
smr
Europe
Cobham uses basically Sepura radios and fit them for airborne use ( = expensive) . So look for Sepura/Cassidian/Motorola Tetra terminal for the same band. If they are using any of the TEA encyption it will be impossible to get into the system for an unauthorized terminal.
Raccon
'Getting into the system' is controlled by registration and optionally authentication which uses TAA (TETRA authentication and key management algorithm). TEA is used for air-interface encryption and will prevent even an registered/authenticated terminal but without encryption from listening to encrypted communication. However the terminal could still listen to clear communication, e.g. where the system has a mix of clear and encrypted talkgroups,
