Question
shoe
Hi I have a Radio Shack 2018 scanner and a Vetch cordless phone .
All play well together except for frequency 155.520. If I remove the phone base unit from the area it works ok.
Is there a filter I can get for this? I get a terrible buzz
cj5
California
the 155 mhz dilemna
Ah, I see you're having problems with a 155MHz frequency. I don't know if I can offer any suggestions, but I sometimes experience a lot of RFI in the 155 range from various things (i.e. cordless phone, wired router, and paging systems in the area). For the paging systems I bought the filter shown at the bottom of this page (http://www.parelectronics.com/amateur.htm) and tuned it for 155 paging frequencies. The router and phone were more difficult to pin down, and even after placing a toroid around the electrtical cords (http://www.radioshack.com/product.a..._name=CTLG_011_002_009_000&product_id=273-104) I eliminated some RFI, but it's still there. The best solution is get all your antennae as far away as possible from any indoor interference.
shoe
Snap-Together Toroid Choke Core you think it is worth a try?
MarkWestin
Caribou, Maine
Rs 273-105
Hello,
I haven't used the 273-104, but I am using a large quantity of 273-105s. If your phone uses an "ac adapter" type power supply, it may be radiating noise from the phone's base through the wire that goes to the "brick". While I can't say for sure that the choke will cure your noise problem, it knocked out the noises from my battery chargers. Just wrap the wire through the choke a few times as close to the jack end as possible. It also works good for serial and USB cables.
cj5
California
It's not a perfect fix, but gets rid of a lot of trashy interfernce. Hell, for 8 bucks it's been the cheapest investment I've had since I started my radio hobby.
shoe
well the 105 did not work any other ideas?
only disrupts 155.520
W4KRR
Coconut Creek
Get a new cordless phone. They're pretty cheap these days.
Or get a new scanner.
Or keep the phone and scanner away from each other.
cj5
California
Al42 said:
Do you have a Linksys router?
Or a router, in general? I did the LinkSys to NetGear switch, then a NetGear to Motorola router, and got RFI from all three. I tend to think that it lies in cheap unshielded ethernet cables. I realized this the other night while playing Enemy Territory. First, I opened up the game, and logged on to a server, and as soon as I did, my scanner kept stopping on any frequency in the 155 MHz area. Disconnected from the game server, and the scanner resumed. Second, and the dead giveaway is turning on my laptop. Now when I turn it on everything is fine, but then I go ahead and plug in the ethernet cable, and the scanner does the same darned thing as with the game, until I unplug the cable from the laptop. At times, while using the internet, the scanner seems to just work fine, but when I am using a heavy amount of bandwidth (up or down), the scanner stops on anything in 155 MHz. Just some trouble shooting ideas for ya.
ex8010
ex8010
I tried to fix a problem with a linksys router by using a shielded cable, and that did not work.
shoe
No I do not
cj5
California
Well, then I could suggest that you check on the adapter that connects to the phone. Sometimes if the adapter is not constructed correctly (most adapters are built to cut down on RFI), and my be giving off unwanted interference.
I don't think that it's the phone itself, because it appears Vtech phones operate in the 900MHz, 2.4GHz, and 5.8GHz ranges. So it leads me to believe that it's a power source thing. If that's the case, go with a toroid choke.
Al42
Long Island, NY, USA
That's one source of interference, but you'll get that all over the house, more or less, and over a wide range of frequencies. If you get a really strong signal only when you're near the router, even with no antenna on the scanner, you're hearing the router's CPU frequency, and that's usually stronger, nearby, that the noise (which is pretty random in frequency) radiated by the cables.
You can sometimes counter hash (which is what you're getting - broadband noise) by tightening up the squelch. Of course this eliminates receiving the weaker stations, but you'll still scan, and hear the strongest ones.
shoe
All I use is a speed stream 3060 internal PCI DSL modem
