Question
radioman1225
so i was looking at Rolla MO for the state's lowband because i knew it was there on the site and now....its not, where'd it go i wanted to put those highway patrol into my scanner
talkpair
Clinton County, MO
buddrousa
NW Tenn
Are you sure all the MSP cars I see only have the new trunking antennas on them now no 6 foot lowband antennas.
I also hear car to car and car to air on the state trunking system.
kruser
West St. Louis County, MO
Attached is a poorly formatted zipped RTF text file I'd created from before many of the old RRDB listings were deleted after Moswin started taking off.
Much of it is outdated and probably no longer in use with the exception of several of the low band frequencies which do seem to still be in use as backups or when troopers cannot be reached via Moswin.
radioman1225
around here i don't know but it says they still do certain things like announcements and testing on it
thanks ill make sure to save it im going to try it on my WS1010
Starcom21
IL / MO Database Admin
Glen Carbon, IL (MetroEast-St Louis)
It's all right here:
If you know these frequencies ARE IN USE. Please submit and we'll add it back in.
They were marked as deprecated some time back because we were told they were no longer using lowband.
Then there were some reports that they were in use, but no actual verification.
As of now, anything marked deprecated in the database will be automatically deleted after 30 days.
I'll add this info to the wiki.
scanman1958
St. Louis
The last time I was in the Troop D area (last fall) all low band frequencies listed for Troop D were in use quite often, but only as a secondary channel. I heard low band traffic quite a bit. FYI
