W2PMX
Or move the antenna so that you can run the ladder line right to an antenna tuner in the shack. (You can use shielded balanced line, so you can run the line near metal.) As far as lightning protection, there's no such thing. (Nothing man-made can protect against 120 million volts at 30,000 amps.
Static charge protection (which also protects from induced voltages from nearby strikes) is different. Use a Blitz-bug or equivalent for coax. If you want to protect at the balanced feeder, you can use a copper block welded to a ground rod. Drill and tap the block for 2 automotive spark plugs. Connect the feeders to the hot terminals of the spark plugs. Adjust the gaps so that the plugs don't arc over on full power peaks, then make them about 1.5 times as large.
But disconnect all antenna feeders when there's active lightning in the immediate vicinity.
