smokeyjones666
- Joined
- Apr 7, 2008
- Messages
- 229
- Reaction score
- 2
Ok, I've been thinking about getting an external speaker and after doing some reading (and using the search function
) I have some questions.
From what I've read, the general consensus seems to favor Motorola speakers. I also notice most of the photos that have tricked-out installs or external speaker setups use those speakers with the blue Motorola logo, which I've been finding on eBay by searching for "motorola speaker" or "spectra speaker".
The problem is I'm confused by the wide variety of model numbers - there are so many different ones. Some have a two pin molex on the end, some have many pins, some have the connector cut off. The ones with many pins usually claim to have internal amplification, which interests me except I can't find an accurate description of the pinouts.
So, if you've connected these speakers to your scanner,
I'd like to hear about it. What model numbers? Did you hook it to your base or your handheld? Does it have amplification, and if it does did you get one with an internal amp and rig it up or did you roll your own amplifier? Is this all hype? What gives?
