Questions on the GRE-300
sifd4x4
Salisbury, NC
I was recently looking into getting a GRE-300 as a Christmas gift to myself.
Anyways I was wondering if someone could tell me if the PSR300 did a decent job at picking up CB radio talk. Im on the fire department so I want something to listen to 800mhz frequencies (fire grounds, police, dispatch) but I also drive the interstate alot and would like to listen to CB but I dont want to have to get a seperate cb radio too. So does it pick up both of these categories well?
safetyobc
South Arkansas
It should pick up CB but to pick up at any distance you will need a band specific antenna. So if you install a VHF High or 800 antenna on your vehicle, you won't hear the CB traffic at any distance (less than 1/4 mile probably). If you put on a large antenna for the lower band CB, you will likely give up hearing distance on the higher bands.
sifd4x4
Salisbury, NC
alright thats what I figured it would be. what would be the difference in picking up 800 with a vhf high versus an 800 specific antenna?
TheJerk
Reading, PA
If you have a good antenna, it will pick up a *standard* (read, non-amplified) CB transmission a couple miles out...but compared to a good cb radio, it will seem deaf.
I have ran one on a external antenna in my truck that also has a Galaxy DX959...the 959 was picking up transmissions that were static on the 300.
