Questions On The Pro -96
DWVFD29
Belpre, Ohio
I Bought A Pro 96 Today And I Live Parkersburg West Virginia
And i Have TheProper Frequencies In For Parkersburg Fire & Police
Departments But I Notice WHen Pfd Is Paged The Page Is Muffled But The Call Is Not I Have The RX On FM And Also Why Does The Pd Radios Cut In And Out During The Transmissions Please Can Someone Help Me I Am New To Digital Scanning
Voyager
Please list the frequencies you're listening on that have the problem.
Also, since the city operates an LTR system, why did you buy the PRO-96 that doesn't do LTR?
Joe M.
MacombMonitor
Joe M.
He does mention he's new to scanning, so I wouldn't expect him to have ever heard of LTR, let alone what it is. :?
MacombMonitor
I'm not familiar with your area, but if Voyager is correct in saying that your city uses LTR, then he's right, your PRO-96 is not the right choice. LTR is something I just became aware of myself. You can read about it here:
http://home.hvc.rr.com/bpetrow/ltr.htm
Take your scanner back to Radio Shack, and get the PRO-97. It's about $300.00 cheaper too! It's an excellent scanner, and as long as you don't need to receive the newer "Digital" modes, it should cover anything else you run into. :D
DWVFD29
Belpre, Ohio
Reply
Parkersburg Fire And Police Are Digital Now The Only Ones Using The 800Mhz Is Public Works The Police Use it Every So Often Now And Then But Fire Is All The Way Digital
MacombMonitor
Re: Reply
There ya go! You now have the perfect excuse to buy another scanner! :D
loumaag
Silent Key - Aug 2014
Katy, TX
Back to the original question...
...WHen Pfd Is Paged The Page Is Muffled But The Call Is Not I Have The RX On FM And Also Why Does The Pd Radios Cut In And Out During The Transmissions...
As to the muffled, I am not sure. But the cutting-in-and-out sounds as if you are not getting a clear signal. It may be too weak or too strong or you are getting interference from adjacent channels. Try using the ATT and see what happens.
wa8pyr
Staff member
Lead Database Admin
Ohio
APCO25 digital does not reproduce sine waves at all well, so they will sound like garbage on a P25 system.
Tom WA8PYR
