So if I use the MO class frequencies on my Baofeng UV-5R I would be able to transmit and receive correct?
Read disclaimer at the bottom, but….
You would set up your radio with the transmit frequency to be the MO and the receive frequency to be the FB2.
You'll need to set the PL or DPL squelch correctly on at least the transmit frequency.
As for the disclaimer….
Unless your name is Laura Mason, you as a student, employee, neighbor, volunteer, amateur radio operator, scanner listener, radio owner, etc. have ZERO authority to transmit on their frequencies. The FCC is very clear on this. The licensee,
--Charlotte Mecklenburg Schools Olympic High School and specifically, Laura Mason (shown as the licensee on the FCC license)--
is the ONLY one who can authorize adding radios to their system. Transmitting on their frequencies, even in an emergency, urgent matter, testing, or otherwise, would be against FCC rules unless you are specifically licensed for those frequencies at that location or have specific authorization from the licensee.
I'm NOT the radio police, and I really don't care what you do. But since you are a new member with a low end Chinese radio, we assume that you probably are not aware of the FCC rules and how they apply in situations like this. What you chose to do or not do is entirely up to you.
