Quick Call II Tones XTS 2500
idle00955
Manch NH
How do I add fire pager tones using quick call to a personality? WHat setting do I need enabled and so on. I have one ch I want fire tones on. Its five tones. I want the radio to alert me when it goes off for that tone. Basically what a fire pager does. XTS 2500I
Devilz311
NJ
It depends on how your tones are set up. You can only decode a maximum of 3 sets of two-tone pages (if they use a common tone).
Basically, the only options for decoding are as follows:
AB
AB/AC
AB/CB
AB/Long B
AB/Long C
AB/AC/Long C
AB/Long B/Long C
AB/AC/Long B/Long C
AB/AD/CD
AB/CD
If each one of your tones are different, you can only have two sets in one system/personality.
Under Conventional>QCII>QCII System; chose the format, enter the tone sets.
Under Conventional>Conv. Personality; select the correct personality, and ensure QCII and the correct system is selected under the signaling tab. Under the QCII tab of the personality window, ensure "selective call decode" is checked.
"and" unmuting will only unmute the radio when the tones are dropped
"or" unmuting will allow you to hear everything.
idle00955
Manch NH
Quick question. Under QCII tab of the personality window on the bottom there is a quick call II call id list. what is that for?
Also can I set the alert tone?
Devilz311
NJ
You can't set the alert tone for the XTS models, it's just a quick "beep beep."
The QC ID list sets which list to encode QCII calls from. In order to send the tones from your radio, the "encode" items should be checked in the QCII tab of the personality window.
idle00955
Manch NH
So basically all I want is to use the fire tones for two towns and thats all. So I followed your method and I should be good correct? I didnt do anything with the QC ID list. I dont want to tramit anything. Just recieve.
