quick call Motorola xts5000
i have a xts5000 vhf set for quick call it works as long as you on the channel is there a way to have radio to scan but not un mute until quick call is received
yaknamedjak
localhost
Yes. You set it to And unmuting. There may be another setting needed I'll check my code plug when I get home in a few unless someone else has the answer handy
Edit, after rereading that. You would have the channel in the scanlist with "And" unmuting
I have two channels on the knob dedicated to dispatch, 1 & 16. I set 1 as regular operating channel and 16 is "And" unmuting under receive settings so that that is my "pager" channel.
Make a scanlist with your pager personality on it but not your operating personality.
Also, if you could add "scanning" somehow to the title of this thread it would probably help others find it, there are lots of threats concerning QCII on the XTS5K
This what i have
yaknamedjak
localhost
Your settings look right, so now you make a scan list with that personality on it and scan that list.
I have scan list with that personality on it with other stuff in the scan list but during scan it receives still until i turn it off and monitor that channel its in and it works i want it while im scanning my ham radio frequencys to not stop on that channel until it receives the quick call it is a model 1 5000 vhf firmware dsp is 17
Sent from my LG-D321 using Tapatalk
yaknamedjak
localhost
Strange.
Do you have to hit the reset button? You're sure you don't have the same channel duplicated on the list with "or" muting?
Maybe something in your priority settings?
You can send me it.
Nope that channel is the one one using that personality
K4RMN
It won't work, you have the same problem I do: those are Plectron tones, see the chart here: https://www.midians.com/pdf/tone-signaling-charts.pdf
I spoke with the Motorola radio tech for my county and he confirmed the tones used by one of my stations are Plectron tones as well and that the XTS5000 and XTL5000 won't react to it due to the sensitivity or method of signal generation Motorola consoles use.
Example: I use a radio that has two-tone signal generation capability to put out a raw tone at the appropriate frequencies, and my XTS5000 alerts. However when my dispatch tones out the legacy Plectron tones on a Motorola MCC 5500 console system to the repeater, my radio does not respond to it, only to actual Quick-Call II tones for my other station.
The 5000 will decode 732 and 1465 for quick call as long as im on that channel but when i go to scan it opens the receive i don't want it to open tho until they send out the tones
