quick ht1250 question
xxbryantd
Im trying to program the p1 button to switch between repeater/talkaround but for some reason when pressed the icon never appears for talk around around and it just makes a beeping noise like its not even programmed, but if I read the radio again it shows the button programmed.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hopefully you've also got a button programmed to Toggle System Scan On/Off. Turn scan off, and the T/A toggle should be OK.
xxbryantd
I have mutiple buttons like scan on/off and monitor, voice play etc. Just toggle repeater/talk around dont seem to work.
Have you tried pressing the button above p3 first then trying to press p1? Sort of like a button for menu select I forget off head but in the cps it has 2 options for the keys on front, short press option and long press which depending on what was picked may make another option inoperable.
Try pressing the usually default unless changed button above p3 for select menu then press p1 see if that toggles the TA on and off, might need to press the menu select again after p1 to basically confirm i dont recall.
Keep in mind also you would need to have your conventional personalities setup to do talk around. In past we always just made a actual channel for talk around over a switch or press. Seems users in some areas have better luck seeing channel 2 as talk around over remembering a switch or function. Both to me are handy however depending on what application is needed.
SteveC0625
Is the personality set up for Talkaround? Tx and Rx frequencies must be different AND on the Options tab, the Talkaround box has to be checked.
Edit to add: Controls & Menus --> Top Level Menu --> The Repeater/Talkaround box must be checked.
I then repeat my advice in my first response: Shut off Scan before toggling T/A.
xxbryantd
Found my issue. Had to go to options under each channel and enable Talkaround for that channel. Now the button is working.
