SDS200 Quick Look
CQ
Exosphere
#1
Finally had a chance to open the package and some physical shots I've seen people ask for.
CQ
Exosphere
#2
Some initial hits on UHF in the short period I played with it while manually configuring all settings and using the shipping database with the stock antenna.
Generic 8GB MicroSD HC Class 10/UHS 1 (7.27 GB free)
Shipped Versions:
Main: 1.06.25
Sub: 1.0.1.10
db: 07/15/2018​
scanman10
Scanner Enthusiast
S.E. Michigan
#3
Seems strange these new radios are shipped with such an old database 07/15/2018. Not a big deal, just wondering?
CQ
Exosphere
#4
I believe the other shipping models had similar old databases. Probably what the latest was during the initial production run and more trouble to update the process.
CQ
Exosphere
#6
A shot of the Ethernet and Micro USB cable plugged in simultaneously. Unless you have thin fingers and long finger nails, you may have an issue removing the LAN cable without a "tool." They should have reversed it since it would be easier to remove the Micro USB cable first and then the LAN cable. Either one is not optimal.
phask
KZZV - SE Ohio
#7
The 536 had a several-year-old DB for a few years, the SDS100 was also several months old. For most knowledgeable users it's no issue as the first thing should be to update DB and FW.
