Quick Look
CQ
Exosphere
Finally had a chance to open the package and some physical shots I've seen people ask for.
CQ
Exosphere
Some initial hits on UHF in the short period I played with it while manually configuring all settings and using the shipping database with the stock antenna.
Generic 8GB MicroSD HC Class 10/UHS 1 (7.27 GB free)
Shipped Versions:
Main: 1.06.25
Sub: 1.0.1.10
db: 07/15/2018​
N8TXX
Scanner Enthusiast
S.E. Michigan
Seems strange these new radios are shipped with such an old database 07/15/2018. Not a big deal, just wondering?
CQ
Exosphere
I believe the other shipping models had similar old databases. Probably what the latest was during the initial production run and more trouble to update the process.
N8TXX
Scanner Enthusiast
S.E. Michigan
You think these SDS200's were built back in July!
CQ
Exosphere
A shot of the Ethernet and Micro USB cable plugged in simultaneously. Unless you have thin fingers and long finger nails, you may have an issue removing the LAN cable without a "tool." They should have reversed it since it would be easier to remove the Micro USB cable first and then the LAN cable. Either one is not optimal.
phask
KZZV - SE Ohio
The 536 had a several-year-old DB for a few years, the SDS100 was also several months old. For most knowledgeable users it's no issue as the first thing should be to update DB and FW.
ColdnFrosty
Nor'east
Hmm .. why does my DB version show 09/24/2013??
CQ
Exosphere
Did you update the master database? I don't bother updating mine often...did mine to prep for SDS200.
ColdnFrosty
Nor'east
At the bottom of the Sentinel window:
"Database Version : 09/24/2013 Target Model : SDS200"
I figured it out. I was using a different account on my laptop and a database from way back when could not be accessed from the new account, so it could not rebuild. It is now showing 02/03/2019.
Houdini7
That’s the one that I have been using since Sunday.
No issues thus far.
