Voyager said:
stateboy said:
The problem with using the input is once a car on F1 with PL keys up, the the system then can hear your radio on F2 without PL, since the repeater has already been keyed by the radio trasmitting PL...this opens up the possibility of the system receivers hearing both radios and allowing them to cover each other.
Not quite. Due to capture effect, one of the two radios will be 'heard' by the repeater receiver. If it's the one with PL, the repeater will activate and pass the audio of that mobile. If the non-PL'ed mobile (or portable) is stronger, the repeater will never see the PL and will not activate - period. If the repeater sees the PL mobile, then the non-PL mobile becomes stronger, the RX will mute and the repeater won't pass any audio (or shouldn't - some repeaters are CSQ audio and PL COS which is the wrong way to set them up).
Granted, capture effect isn't absolute, but if the signal is strong enough for the repeater to see the PL, it is strong enough to hear the audio on the PL'ed transmitter.
Joe M.
Re-reading my post, I left out info that I shouldn't have. It is:
If the situation is one that if radio "A" with PL on F1 is keyed up, and a radio "B" without PL keys up on F2 during the middle of A's transmission and captures the receiver, then it will cover A's transmission and drop the repeater unknown to the user of A...which is not good and poses an officer safety issue.
In my post, I made it rather vague...my apologies. You did mention it though.
Also, I realize that if the F2 radio doesn't have a PL, it won't key the repeater....but it does create nuisance issues like above with F1 traffic if it's non PL signal is strong enough.
Been there, seen that...in both ham and public safety. They wondered why it was so easy to interfere with them, even though the suspect radio was not transmitting PL :roll:
Regardless, it is still better to use the output for a T/A channel...less chances of interference or missed info due to the problem mentioned above.
