Quick question:
INDY72
Indianapolis, IN
Is it possible for one side of a conversation on a conventional VHF system to be analog, and the other half to be digital?
In other words- Dispatch analog, and mobiles digital?
WayneH
Forums Veteran
Super Moderator
Your master site
Yes to an extent, you can set it all up however you want. An ASTRO radio can be set up to receive either analog or digital but from what I recall, transmit in digital only. Analog TX is analog Rx only.
When it comes to consoles the digital transmission is done by the DIU. So it's a matter of setting up two channels, one for analog and one for digital. I'm not sure why you'd want to, but you can.
-Wayne
INDY72
Indianapolis, IN
Just curious.... since I monitor one conventional system that uses both full encryption, and one way encryption.. it got me to thinking, could this work simularly with digital to analog....
Mobiles encrypted, dispatch analog.... mobiles digital, dispatch analog....
Thanks for the input wayne
INDY72
Indianapolis, IN
You can hear dispatch clearly, and the mobile side will be using "secure", in other words encrypted. Its set up this way on some TRS's also... seems to be a common thing now. But the agency I monitor only does this for special ops, and narcotics. I have never heard dispatch go encrypted yet,.. only mobiles. And yes, I am very very sure its encryption, nothing else in the world sounds like encrypted comms.
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
I never new that they set it up that way. Sounds kind of half ass dose it not? :lol: probabley because there consoles don't carry no encryption capability or it is a money thing. So are you monitoring the normal trunked frequencies for this or the inputs? I think you are just monitoring the normal trunking. Have to forgive me there is a encrypted talk group over here and just did not hear dispatch on it yet. Although it might never have dispatch. One day! You did say some trs's so this one might not do that.
What is the DIU?
INDY72
Indianapolis, IN
This is an VHF conventional system. But the same technique is being used on some TRS's. If you ever have a lot of spare time.. browse through the entire listing for Public Safety TRS's on the DB.. you will find at least four that have one way encryption engaged.... dispatch clear, mobiles encrypted,.. but they use it full time on the TRS's.... Whereas its only done so far on specail ops, and narcotics for this conventionl system.
grem467
Houston, TX
wayne_h said:
Yes to an extent, you can set it all up however you want. An ASTRO radio can be set up to receive either analog or digital but from what I recall, transmit in digital only. Analog TX is analog Rx only..
-Wayne
not true, mixed mode RX can be set in both analog TX mode and ASTRO TX mode.
