R15 Firmware
carcarjg
OpenSky > P25
DEE00
So I've got R15Csomething. And I'm trying to program my P7200 for ham band stuff and every time I program I get this error. and the radio doesn't program. Does anyone have the firmware for this? Its running R12C02 currenly.
carcarjg
OpenSky > P25
DEE00
Hang on, what ham stuff are you trying to program into a P7200?
Sorry for the wording. I meant like scanning local business and stuff along with local analog stuff.
I would say do radio maintance ..click on .radio info first ...to read the credintials first
No can do. It doesnt read it. Guess I need to track down this firmware version?
snoopyII
On the other side of the tracks
What version of RPM are you using? It sounds like you have a Firmware/RPM compatibility issue. R12 firmware (ECP) is ancient, it pre-dates XGP which itself is pretty old by firmware standards.
carcarjg
OpenSky > P25
DEE00
Rpm15c.
Forts
Ontario, Canada
If you can get your hands on it, I highly suggest R06L07. Run that on my XG75p without any problems.
He's using a P7200.... Not an XG75. The latest XGP code for the 7200 I believe is R06D13, where XLP on the XG series is R06M03.
carcarjg
OpenSky > P25
DEE00
Wait. The latest for the 72 is R06D13? Is Harris counting backwards this time around? Or is that RPM2 firmware?
Forts
Ontario, Canada
It gets confusing with ECP / XGP / XLP versions of the firmware. For the 7200 the last ECP version was R16, then it switched to the XGP platform which goes up to R06 (I believe they stopped adding new features around R04... it's just bug fixes beyond that). With newer radios like the XG-75 you can run the XGP or XLP firmware (XLP being the newest...). The R06 versions work just fine with RPM 14. You really only need RPM2 for the XL-200p etc. I have XLP R06M03 in all my radios (XG-75, XG-75M/M7300, XG-100P Unity) and program them all with RPM14.
carcarjg
OpenSky > P25
DEE00
Ah, Cool
snoopyII
That's a interesting pic. Forts is correct though, officially, the P7200 is not a supported radio for the XLP series firmware, there is no software part number listed in the SRN. Whether or not you can force it in is another subject, but it appears you have demonstrated that you can. What file did you use? Was it "R06L07_PORT_IQ.cmp"?
Forts
Ontario, Canada
Hmm, are you sure about that??
I'm only going by what's available on PSPC... Last XGP release for the 7200 was 2016 (R06D13).
Interesting file you have there. The only 'L' series XLP release I saw was R06L01.
AESFTW
Fultondale, AL
I had R06L01 loaded in the 7200 prior.
AESFTW
Fultondale, AL
Yes it was, no problems whatsoever. The 7200 works great besides a volume pot I need to replace. Feature 47 about to be ordered.
