I had that same problem!Thanks, I see the options now. I didn't realize the Quick menu was context-sensitive depending on the mode.
The R30 portable has the same issue where the Quick menu can be different when you use it. I guess it's also dependent on the mode when you use it.
I was referencing the 8600 in my last post but I did mean the R30.
Thankfully they both share the same features!
The R30 also frustrated me one evening.
I was listening to headphone audio in WFM mode on 912.500 MHz.
All of a sudden, my audio was gone but I still saw signal. After messing around with the radio thinking something had broke, I realized I'd somehow hit the key to switch it from VFO 1 to VFO 2! VFO 2 does not support all the modes that VFO does. Or is it the frequency range that is different? I don't remember until I look at the radio again but I think it's the mode that VFO 2 does not cover all the modes that VFO 1 does.
Being as the R30 shares the same memories and memory banks between VFO 1 and 2, it's easy to switch over to VFO 2 and not notice you are not receiving some things. The radio should be capable of giving you some kind of warning when you switch to VFO 2 from 1 with a mode that is not supported. Oh well, I did get used to that small quirk!
