R7 SCAN Mode
Rudy3145
New York
Every time I turn on the R7 - I have to set an active scan list (I only have 1 list) to get my scan button to function. My side top button is scan on/off.
Is there a way around this?
Rudy3145
New York
When I copied and pasted a code plug into the R7, the scan list never migrated/pasted over. So, once I assigned the scan list to the freq, eveything worked fine. My fault for overlooking it and assuming the scan list would migrate over.
N4KVE
PALM BEACH, FLORIDA
When I got my R7, I used the migration function in CPS 2. I read my 7550 & programmed it to the R7. Everything took except the scan list. So the next day I did it again, but used my 7550e as the master radio. That time the scan list went to the R7. I don’t know why it made a difference, but it did.
Rudy3145
New York
I'm better versed at programming Apx, and also a much bigger fan of the programming software vs programming TRBO.
Rudy3145
New York
So Im doing another R7. I have scan / edit / select new list enabled in menu. I have multiple scan lists and all freqs are assigned to a list.
When I go into menu, then scan all I see is the option to turn scan on/off. Edit and select new list are not visible.
Any suggestions?
Rudy3145
New York
FYI, if you have all scan options enabled & have created scan lists (but can not choose list, edit list etc. from Scan in menu) these steps must be done per Motorola.
Root cause - Front programming password in the radios configuration/codeplug is set to disabled
Workaround/fix - Set the front programming password option in the general settings section of the radios codeplug/configuration to either User or Dealer. The front programming password field is the third from the last field in the section.
Why the front programming password would effect the scan list options? I don't know. But it does.
YL3IM
KO26BX
Should have pasted twice as contacts, channels and different lists depend on each other.
