I have an icom R7000 poor sensitivity typ only -103 dBm. I have another R7000 way better sensitivity. I suspect Icom (SAR in michigan) will tell me they no longer repair them. SO WHAT DO YOU DO THEN? Is there a REPUTABLE repair shop?
Did you consider to replace it with a R7100 in good conditions?Ok so I talked to Matt at SAR today. As expected he told me he isnt accepting R7000 ..period. I asked him twice what do I do now? He eventually said all the people he knew have "either retired or gone away"
I really like these radios. Is there really no one out there can fix them? Do ya just throw it away?
I have the service manual. I have mainly had DC DC box go bad ...capacitors..If you can get a copy of the service manual many of the adjustments are merely voltage based when tuned to a specific frequency so aligning it can be partly done with nothing more than a voltmeter. I had done several R7000's this way and they worked much better after such a partial alignment.
There have also been sellers on eBay of Capacitor Sets to replace the electrolytic caps on the R7000, which seem to be a big issue. I have not done this lever of work but I have heard from others that with a reasonable set of soldering skills, patience and the right parts is doable.
If I recall correctly ICOM had a bulletin for this problem. The capacitors in the power supply get weak. AC ripple appears on the circuits. The RF stage tuning uses varactors. The ripple sweeps the tuning all over the place. The power supply should probably be recapped before you start troubleshooting elsewhere. Note if you unplug the DC jumper at the rear, the power supply will climb to 19 volts perhaps more. This is "normal" and is due to a bootstrap resistor across the series regulator. DO NOT plug the jumper back in until you have powered the AC off and allowed the capacitors to bleed down. You will blow the grain of wheat lamps in the front panel and perhaps damage other stuff.I have an icom R7000 poor sensitivity typ only -103 dBm. I have another R7000 way better sensitivity. I suspect Icom (SAR in michigan) will tell me they no longer repair them. SO WHAT DO YOU DO THEN? Is there a REPUTABLE repair shop?
The difference is that older radios used common components that you can still buy today. Radios from the 1980s started using specialized solid-state devices, particularly digital devices, that are no longer available and that nobody has duplicated. Go to a hamfest and you are bound to find someone selling boxes and boxes of old vacuum tubes. But, guys selling old ICs are rare.It is just a sad state that some can resurrect tube radios from the 30's. But no one available to work on a 1980s radio?
Also remember that in the vacuum tube days radios were intended to be serviced and repaired while newer ones were not. While Icom (as well as Kenwood, Yaesu etc.) are serviceable to a point, that level is nowhere near to that as in the past.The difference is that older radios used common components that you can still buy today. Radios from the 1980s started using specialized solid-state devices, particularly digital devices, that are no longer available and that nobody has duplicated. Go to a hamfest and you are bound to find someone selling boxes and boxes of old vacuum tubes. But, guys selling old ICs are rare.
Before we get too nostalgic it might be good to consider that that was design out of necessity; those radios required regular servicing (unlike my R7000, which worked flawlessly for ~25 years without any maintenance whatsoever).Also remember that in the vacuum tube days radios were intended to be serviced and repaired while newer ones were not. While Icom (as well as Kenwood, Yaesu etc.) are serviceable to a point, that level is nowhere near to that as in the past.
You betcha! No tubes to be replaced like my old Hallicrafters and Zeniths had! As for alignment it was at least 15 years old before my first R7000 alignment, it worked OK before then but was not as sensitive as some of my scanners of the time (PRO2004/5 vintage) so the volt-meter portion of the alignment worked well.Before we get too nostalgic it might be good to consider that that was design out of necessity; those radios required regular servicing (unlike my R7000, which worked flawlessly for ~25 years without any maintenance whatsoever).
Yes I have another R7000 that is still very sensitive. Bought it new in the 1980s. I wish this one I bought used had same sensitivity. It affects scanning searching everything. Again thankfully I can return it next week for a full refund. It has a discriminator output, I wonder if this is how the noise creeps in? Especially if not buffered.Before we get too nostalgic it might be good to consider that that was design out of necessity; those radios required regular servicing (unlike my R7000, which worked flawlessly for ~25 years without any maintenance whatsoever).
Search for a good R7100. I had one in the 90s and it is very good in VHF and UHF bands.So what can I buy (not a handheld) that covers VHF and UHF aviation and Mil Air? I will have $400 min.
