R7100 Help
rjr52
Charlestown, NH.
Can someone please tell what the edge frequencies are for the basic scan operation? I tried entering 144.000 into OP1 (default Freq) then 148 into OP2. Op2 reverts back to 146.000. It seems like no matter what I enter it doesn't hold.
Thanks in Advance
RJR
W3DMV
Gettysburg, Pa
Press up/down memory ch buttons to select OP1
Key in "144" and hit "Ent"
Press TS and select channel spacing using main tuning knob and shown on main dial
Press approperate mode switch to select mode you will scan in
Press "MW" button to write info to OP1
Press up/down memory ch buttons to select OP2
Key in "148" and hit "Ent"
Press "MW" to write to OP2
To scan these settings, press "Scan", "3" and it should scan your range...
Scan "3" runs the "OP" banks and Scan "6" runs the other banks 100, 200 etc
