Has anyone used an R820T in a Windows virtual machine from a Mac? I can't seem to get the USB driver to work.
VirtualBox. Latest version. I did download the latest zadig drivers. The R820T came up as a Realtek device. I'm using SDR#, but doesn't matter since there's no RTL-SDR/USB seen by Windows.Are you running parallel desktop or vmware fusion? Did you download the latest Zadig drivers?
Make sure you install the 32 package even if your on a 64bit machine
Zadig - USB driver installation made easy
What host app are you using for the rtl
Sdr# or HDSDR?
Same results. I think that Virtualbox just doesn't do a good job with audio.Lower the sample rate of the rtl in sdr sharp click on the gear icon on the top left. Lower it to about 1 mhz
of bandwidth
