fasteddy64
Antenna question: I have an 8600 on the way and I want to use it with my AOR SA-7000 antenna. The antenna covers 30khz through 2ghz but only uses one feedline. What is my best option for connecting the antenna to the 8600?
Disregard, I looked at the manual online and got my answer!Antenna question: I have an 8600 on the way and I want to use it with my AOR SA-7000 antenna. The antenna covers 30khz through 2ghz but only uses one feedline. What is my best option for connecting the antenna to the 8600?
I know this is unrelated but what do you think of the SA-7000? I remember reading about it ages ago but I never found any user reviews of this antenna.
I've owned a couple of these over the years. I found it to work very well on the 700-800MHz band. After removing the top 3'rd element of the longer vertical element I found it to perform very well as a dual band VHF/UHF aircraft antenna. I sold my first one to a friend and he put it up on a 30 ft tower with a 10 ft mast (40 ft total) at his cottage in Lexington, Michigan (North of Port Huron), just off Lake Huron. He also found it to work well on 700-800 MHZ as well as the Marine band, FD & EMS VHF.
View attachment 104858View attachment 104859
For a second there I thought this was a pic of my SA-7000, it's installed exactly the same.
So far so good. I don’t have a lot of antenna options right now and this one is doing quite well. I monitor two 700/800 MHz systems, Some VHF conventional ad well as VHF and UHF air. I am very pleased. HF seems very good too but I haven’t spent a lot of time there yet.I know this is unrelated but what do you think of the SA-7000? I remember reading about it ages ago but I never found any user reviews of this antenna.
