Racks in the shack
firetaz834
Metro Area, MI
An idea to consider might be what some radio shops would do or how equipment is mounted in a command post. If your using equipment that is trunk mounted then mount the control head on a shelf and the trunk-mounted unit on the floor.
I'm sure that if you check out the other posts you can find photos of how others have handled mounting that type of equipment. Hope this helps.
Dustin
Here are two scanners I have made to fit in 19" racks.
Dustin
Dustin
Here are a couple more rack mounted scanners, a Pro 2042 with lighted signal meter made into a Novex rack. Also a MR8100 made into a aircraft panel, found out the hard way it's not exactly a 19" rack but I will figure out someway to mount it.
Dustin
kd8bao
Medina, OH
Still working on cleaning up wires but this is it for now. Have 3 feed going now. 2 actual radios and one scanner. Power supply, HP quad core tower, 4 camera video center, 1TB network back up and an APC back up. All equipment sits on shelves.
PACNWDude
Emergency Comms trailer and ship rack mounted radios.
Here are some radios rack mounted. In one there is an old school Motorola Centracom console and Spectra Consolettes in 19" rack mounts on board a ship. This was about 10 years ago. The other is a trailer for emergency communications work that has a radio rack in it. This one uses Telex gear to remote control the radios.
forums manager
Super Moderator
Staff member
Folks, lets remember this is a family oriented website. Lets keep things more on-topic next time.
DisasterGuy
Maryland Shore
I use a in-house version of these: Radio Specific Power Supplies for racking up control stations at sites. Most were made with blank rack panels, cut two openings using a cut off wheel and then using a console face plate bolted on to hold the radio and give it a tidy look.
