RACOM system-wide rebanding starts Feb 1st
Radioman96p71
A rapid, system-wide rebanding is set in motion beginning February 1st. RACOM is looking to switch 2 sites every day to the new frequency plan.
More information to come.
Pella and Malcom will be switched in the near future, either today, the 2nd or tomorrow. So anyone in that area would please reply with changes i would greatly appreciate it!
They are looking to make this as rapid as possible to eliminate issues with radios not roaming properly.
Thanks in advance!
Radioman96p71
New system LCNs:
(I will add to this list as i confirm them)
Site Name:__System:__LCNs:
Pella _______2________(1) 856.1375, (2) 857.1375, (3) 858.1375, (4) 859.1375, (5) 860.1375
Malcolm or Newton seems to be rebanded also but from my location i cant tell which one im hearing. Is there anyone in those areas that can confirm a strong control channel on 856.7875?
Radioman96p71
OOOOK well i thought i could edit my previous post like on other forums, but with the help of Fireside, here is the New LCN list for Newton:
System: 6
LCN: (16) 856.7875 (17) 857.7875 (18) 858.7875 (19) 859.7875 and maybe (20) 860.7875 (not confirmed)
Radioman96p71
Malcolm is getting rebanded today, please let me know if/when the CC drops. Thanks
fireside
Tama IA.
CC 858.1875 , now techs are testing with voice coms, channel 11
Now 857.1875 CC but not very strong.
Radioman96p71
Malcolm:
System 8
LCNs: (10) 857.1875, (11) 858.1875, (12) 859.1875, (15) 859.1375
All confirmed
Radioman96p71
TY for the sticky
Tomorrow will be Cedar Rapids, with Iowa City switching over Friday.
Anyone in that area willing to do some scanning when the switch happens? Thanks in advance
newsphotog
Des Moines, IA
Wow, this is going to be a mess. Thanks for keeping track of this for us. I'll contribute what I can, but I'll bet you have a better grasp of the Des Moines metro systems then I do. :lol:
Theoretically, we would know about all 12 or so of these frequency sets before rebanding is complete?
N0GX
Iowa
I'm new to trunking. I programmed my bct-15x with freescan and radio reference. So if I want to listen to Malcom now, all I have to do is change the old freqs to the new ones listed above? Is that correct? Do I need to change anything else on the Malcom system in my scanner?
Thanks, Kyle K0KJL
timkilbride
Linn Co Iowa
TY for the sticky
Racom, Cedar Rapids CC still 861.7875 this AM. I will check on this through out the day.
Tim K.
timkilbride
Linn Co Iowa
It may be to early to tell, but will each system have the same frequencies like it is now after the re-banding?
Tim
Radioman96p71
Tim K.
Tech is enroute Cedar Rapids 2, which is the south site, i beleive. System 13. Heading to the north site after that.
K0KJL: The LCNs also changed for that site i beleive, so you will need to put them in the order above. Instead of channels 1,2,3,4 in your scanner, it will be 10,11,12, and 15. Make 13 and 14 a blank channel.
newsphotog: There is something fishy goin on, they are giving the new systems letters now. They mentioned that after the switchover is complete, there will be another ProFile blitz to put the new freq in the radios and get rid of the old. What makes it weird, is that they said older radios, (non RPM to be exact) will not support the second phase because "there isnt enuf room for all the old and new" Which makes me think that they are either going to give each site a designator, or for some reason some radios wont be able to have enuf SYStems in their flash. Time will tell on this one. I was hoping they would just modify their existing 'master frequency plan' but im sure an endeavor this large would overlap more than it would be useful.
This early in the game its hard to tell what order, if any, they are going in. My money would be they are switching over ancillary, non-critical sites first. Saving the large, multichannel sites like Des Moines, Marshalltown and Waterloo areas for when they can designate more manpower to make it faster. At the rate they are going we should find out soon enuf!
timkilbride
Linn Co Iowa
Is there a program I can download that will tell all the LCN's once I find the CC? I have a 996t w/ DISC tap.
Radioman96p71
I use UniTrunker, you can get it from the WiKi here. Makes finding active LCNs a breeze. Still need to find out the actual frequency, but at least you can watch for activity this way. Unitrunker's Site
HeartThrobs
Black Hawk County, Iowa
Malcolm:
System 8
All confirmed
To find the RACOM reband licenses do a ULS Advance Search for:
Radio Service = YM
FRN = 2579704
Status = Active
I compared the Malcom (WQKD878) reband license with what you found in the real world. The only issues comparing the two are
1) 859.1375 isn't on the license.
2) 854.1875 is on the license and not listed above.
And of course no LCN on the license.
Will see how this goes as more are rebanded.
mushr00m
iowa
Cedar Falls
I've been unable to scan on the Cedar Falls tower, but I can hold on TGID's and it will pick it up. I dont get it, does this usually happen if its been re-banded? Does anyone have any info on how to get the new freq's for Cedar Falls?
