As a rule of thumb:
antennas under five-feet (5’) aren’t worth much. Physical length counts, not just “longest to a predetermined height”.
I drive a semi. Besides the
direct work-related benefits
I already have experience where Citizens Band is the only way to communicate with any range. Hand signals and visual aids only do so much.
So,
forget the drive-thru. One will still survive.
As to parking garages, I’ve had antennas mounted on Hustler Quick Disconnects to stop and pop them off for low clearances.
My pickup roof is such that a 9’ whip puts me at just over 15’. For GP, that’s too tall by a foot.However, a President
Texas puts me to under 13’. A five-foot
Skipshooter keeps me under 11’.
On this Peterbilt, clearing 14’ makes nearly all miles obstruction-free. Yes,
I have to alter route-planning in rare instances Truck needs 13’6” clearance.
Most municipalities REQUIRE 15’ clearance for emergency vehicles (tree branch height). Snow, ice, heavy rain can cause those branches to droop. It’s been rare I’ve had a conflict past these circumstances.
Mindfulness is in play.
Are you
sure you couldn’t use a roof-mount? Everything else won’t be much of a performer by comparison.
If distance (faint contacts) really matter.
Breedlove Machine Shop
is where to find the 3/8 or NMO permanent antenna roof mount.
I ordered a PRESIDENT
Lincoln II+ radio yesterday. They’ve gone OOS at some retailers. Excellent SSB performance (a
McKinley is next step down)
I want the mount (part of the antenna system) to be as good as it can be. Some “inconvenience” (new habits) doesn’t any longer figure. I’m good to 14’ in the Peterbilt and — from experience — know I’ll be able to run UP to that height in the pickup (and where a 5’ antenna is under 11’ as the performance minimum).
What you hear may matter (serious consequences) only ONCE. So, like seat belts, the installation and habit of use are critical for that one instance.
Let that be your guide.
Mobile Install
I’m a long ways from home many days of the year. I’d prefer to avoid that which might prevent my return. A CB
performing to its full capability is central to preparation.
“Learning to listen” is a whole other subject. As putative CONTENT isn’t always germane to understanding, only an aspect.
The game-changer with AM/SSB radios is the outboard addition of modern Amateur equipments incorporation of
DSP. Variable digital signal processing of RX before it hits the speaker.
Your radio is better than you think. And there’s no substitute.
I use a West Mountain Radio CLEARSPEECH DSP Speaker. Bounced it thru the oilfield and OTR the past six years. I’d no more leave home without it than I would leave without a CB Radio rig in any vehicle.
Other radio choices (and scanners) aren’t precluded. You’ll find that there are MANY other intelligent men with HQ CB rigs aboard work vehicles. (Quiet until it matters; just monitoring).
Everyone has a mix of info from other sources to offer.
Devil take the hindmost.
