To all who reported the problem: Lindsay repaired the problem with sub-fleets not appearing in Radio Communications System (800 MHz) and possibly other Moto systems...
There is a tentative Fleet Map posted in another recent thread that is better than the one listed under RCS, but I am still testing it.Thanks, guys. I've been closely monitoring the Downs and Derby Festival channels since Thunder. Loads of activity. Derby Day should be a blast.
Best...A.
Thanks,Radio Communications System (800 MHz) Trunking System, Louisville, Kentucky - Scanner Frequencies
Its just some raw data for alphabravo, to work out the fleet map assignments.
They will download with scanner software, but it depends on if RR has the right (information) codes, right now 1-2 need changing. (Which I will post and send in when I get a better analysis completed).I'm confused on what these things are and how I should program my scanner for them. Can you enlighten me?
Thanks!
Let me know how it works for Derby day, if you are over in this area tomorrow.New Fleet Map added to Data Base....
700-12 is Brantley services, they acquired it last year or the year before... they handle event management. (and transportation too).I'll be at Keeneland/Lexington for the Derby and possible nasty wx.... Did a lot of listening this morning and last night, many of the 700- ids were good.... apparently 700-12 is Parking/Brantley at Churchill and at least one other group, also at Churchill.... there was a discussion early this morning where one set of users needed to talk to themselves and one of the other sets of users kept answering.... 700-12 is "Channel 1" for the other group, never could find "Channel 2"--they went to it following the exchange above... possibly they are using an input freq as a TA.... don't know what to do with all of these TGIDs that have been submitted, they may or may not work with the new fleet map...
Beats me.. Both software programs that I use.. basic steps co like this:Maybe I'm slow, but how do you find this system using the download method on arc-xt pro?!?
