Radio error under proGrammer
merlin
DN32su
OK, got another box of M-RK radios and trying to read from them. Seems the radios were programmed with a newer version and that is where it all ends.
Thought I had the latest version, files being 'R17A05.
Anyone know where I can get my hands on newer updates ? or just getting this to work ?
Note, not asking for software, I have that, just trying to read the new radios.
merlin
DN32su
Note: someone suggested I need the RIB but looking at the schematics, connections are much straight through to the com 1 port.
Allbeit, this is a different computer, same software and setup that worked before.Just puzzling.
Difference is new radios ar 800 Mhz. They do wake in PC program mode.
merlin
DN32su
OK, after farting with this setup for 4 hours, I finally got it to work on all the M-RKs, now for something practical with them.
merlin
DN32su
I believe ProGrammer ended with version R20. After that, starts the RPM series of software.
I believe so also. I recall this is ProGrammer V. 18. It works with all my M-RK radios, but sheesh deciphering the hex files created. Found channel names with a hex editor but I need frequencies to go with it. One of my 450 radios has only one RX channel and would be cool if I could set a TX and a couple extra channels. This utility makes Baofeng and Icom like kindergarten stuff.
merlin
DN32su
Don't really know that I need RPM. I might when my Jaguar700P cable comes in. This has my radio on the list.
Help says it will work on a channel by channel basis, but no such animal found. The radio shows 'PC PROG' 'APP CMD' and that is all.
I can get RPM for $150 if I really need it.
merlin
DN32su
OK, some reverse engineering this problem is solved. Mainly unknown/undocumented steps to follow and very picky.
