Ok, I know you can stream the Unit Ids using this %U. But how can use stream the Alpha tags for the unit ids ?
With ProScan you have to add it in your METADATA Source. That tells it what information you wish to send as a TAG. With Radio Feed it's under the METADATA tab.Ok, I know you can stream the Unit Ids using this %U. But how can use stream the Alpha tags for the unit ids ?
