Radio Id's on 536hp?
bama9999
Gulf Coast
On the radio itself, click "Menu" then scroll to display options and press enter. Then scroll to Disp. Unit ID and press enter and select On. Then just keep pressing menu until you're back at the main scanning screen. You an also enable it in Sentinel.
ofd8001
Louisville, KY
Also, if you change the setting in the scanner via the keypad, be sure to either change the settings in Sentinel or do a read from scanner in Sentinel.
If you write to the scanner a later time using Sentinel, without doing so, the settings in Sentinel overwrite what you have done in the scanner via keypad.
twoxland
Winona,MN
Thanks! This radio has a bit of a learning curve compared to my psr-800 but I'm slowly getting the hang of it.
