Radio Keeps shutting off
a417
I would still highly advise against using that cheapo antenna adaptor on a whip right next to your new power supply. You seem to be throwing money at the wrong part of this temporary problem. The part that you say "you want to do it correct" is highly suspect if you're not doing "proper" antenna installations and setups.
KG5HHS
D/FW
I am looking into doing both the power supply AND antenna installation correctly. Are you saying that antenna solution that I am referring to in post 17 is not a good solution?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I believe that 15 A might not be enough at 8 W. Also you have other things running on this power supply. Try turning everything off on the power supply and transmitting at 5 to 8 W. 15 A should be plenty for that.
I believe The problem is in the power supply. Maybe you have a faulty one. Is it 15 A continuous.
Roger
A 15A power supply is more than enough for a 50w radio to transmit on high power.
Likely the issue is him transmitting with the antenna directly connected to the radio, causing RF to get into it.
a417
the way your post-train-of-thought has been proceeding made it seem like you wanted to throw money at a fancier power supply , without getting the RF out of the unit in a way that will not affect everything near it. Get a remote-able antenna up, with proper feedline (you can get RG-8x, an NMO mount that you can put in an old sheet pan, and a whip for a pittance these days - much cheaper than a bigger power supply) . Get the friggin' RF away from that power supply.
All the standby power in the world won't help if you can't get the RF out of the radio.
KG5HHS
D/FW
I'm not sure what a remote-able antenna up is but I am going to order the stuff listed in post 17 and get that antenna outside the house.
KG5HHS
D/FW
And away from the operator and the radio. Bad practice, RF Exposure, and that was on the test.
I understand this is a 50 watt radio, but as I've mentioned earlier, I have it turned down to low power. I was under the impression it was only 5 watts, which is no more than my portable, but I will check and see for sure when the swr/watt meter comes in.
a417
:cautious:
It's a sort of a portmanteau for "remote capable" antenna. Rather than be absolutely literal with what I meant, I took some liberties with the words used. Apologies, won't happen again.
I see your followup post also says "but i turned it down to 5watts..." as we mentioned earlier which you are still shooting directly into the power supply. Put a length of coax between the antenna and the radio, MOVE THE EMITTED RF from the immediate proximity of the power supply, and try again.
you also said in post #17 you want to do things correct.
KG5HHS
D/FW
:cautious:
:oops: I'm pretty familiar with the English language, so I understand you were combining words there. At any rate, I still don't know what a"remote capable" antenna is. I've never head the term before. I completely understand the RF Issue now. It's been made very clear. as mentioned before (again, in post 17) I do want to do things correctly. I plan on putting a mobile to base conversion kit with mobile antenna outside as to MOVE THE EMITTED RF. I am simply trying to figure out if this solution is correct or NOT.
a417
How many people need to tell you that moving the RF away from the back of the radio is most likely the solution before you believe it, and stop pointing fingers at the power supply?
You're obviously frustrated with this, I understand that. But you're arguing semantics when the issue here is practical application. You first thought it was the power supply as the root of the problem, which it is ...and it isn't. That model might not tolerate even the 5 watts ERP you are putting out in close proximity, and may cut out when used at particular frequencies. I see you've had your license for almost 5 years now, there are hundreds or maybe even THOUSANDS of licensees here with DOZENS of years of experience that are all going to tell you the same thing. Your antenna setup AS YOU HAVE NOW is the weakest link in your system. Buying a new power supply, as you alluded to very early on in this arduous thread, might solve that transient problem as you have...but the poor practice of having a whip on the back of a transciever unit isn't helping you. Sure a newer biggier more-better fancier power supply (RM-35 linear type) might prevent the shutdown under certain frequencies issue you're having now, but the bigger fact remains...you are exposing that current power supply and yourself to unacceptably high local RF conditions, even at 5 watts.
you can literally get a $10 dollar mag mount antenna, a length of coax and appropriate connector for that set up, stick it on a ground plane and see if the issues persist.
I'm not going to argue with you over this any more. Your current set up is not in the best practices of the hobby, that is why you are having issues. All that stuff you keep referring back to in "post #17" means nothing if you don't do it.
Get a remote antenna, some coax, some connectors...hook the radio up correctly, get some distance between your transciever and the power supply and try it again.
Good luck.
KG5HHS
D/FW
Good luck.
I'm not sure what your hang up is, when I have made it perfectly clear that I have realized the problem, but its getting no where. The power supply NEEDS to be replaced PERIOD! due to the RECALL alone! I'm well past the power supply, Its a done deal, new one is ordered and on its way, there is nothing else to say about it! As I said before, I COMPLETLY UNDERSTAND the RF issue. I COMPLETELY UNDERSTAND that the current antenna setup as is, is an issue! No one is arguing that! I have comprehended what others have said and no one needs to keep telling me to move the RF away! It wasn't mentioned until post 10 about the antenna issue. and if you will notice, my next reply after that was about trying to figure out if conversion kit setup would be correct. I have mentioned several times about a very specific antenna solution since I have realized that the current antenna setup is not working! I have even asked you specifically if you though is was a good solution! I understood what you were saying about the mag mount antenna but I rather have a more permeant solution which is why I asked about the mobile to base conversion kit. Your absolutely correct about this thread becoming arduous!
Thank you to everyone that helped point out what I need to fix in this setup, I appreciate all the help. At this point, everything has been ordered and is on it's way.
kayn1n32008
Sector 001
The RS-20M runs 16a continuous. As I suggested above, go with at least the RS-35M (if not the 50) and do it right the first time..
Good lord. A 50w radio with a properly tuned load should draw less than 12A. How many radios do you think he will be talking on at once?
w2xq
Burlington County, NJ
As I said above, I prefer my power supply to loaf at a ~50% load. That's me... and my usual reccomendation. Further, the larger power supply should easily run additional radios, e.g. an HF transceiver, and receivers KG5HHS may buy in the future. Over to you. :)
