Radio Ordering, Compaing Help
RadiationX
Oklahoma
OK, I am wanting to get a Icom R75 shortwave radio, online i can get one for around $575
brand new, If a go to a dealer here where i live THEY WANT $800 for one, what is the deal
shippind and handeling is only like $20 and ive gone to two different places, and I have a Grundig G5 will this ICom be any better that the Grundig????
Some One Please Help Me
Turbo68
East Devonport,Tasmania,Australia
Hello,you would be better off buying an ICOM-PCR1500 or the PCR-2500 and it cost around the same price but you have yourself a wideband receiver and you can also use to listen to HF.
Regards Lino (Melbourne Australia)
K2GOG
Mid Hudson Valley
or you can get an Icom IC-718 (or any other Ham HF radio) and if you someday plan to transmit on it, you have a radio that will do it already.
NE Missouri
I would go with the R-75. While there are Icom's new computer controlled black box radios but their HF performance is an unknown quantity. The R-75 is a known quantity and well regarded receiver and a very good performer especially now that they come included with the DSP option. If this is your first “big” HF receiver I would definitely say go with the R-75 and leave the computer controlled gear for the next purchase. Just my opinion of course.
You should see a remarkable improvement over your grundig radio if it is the model I believe it is. I say that with qualifications. That radio will only be as good as it's antenna. You need to connect that R-75 to a good outdoor antenna or it simply isn't going to perform. Paired with a good antenna the R-75 should perform great and well, spank your grundig.
Bill_White
Perry, N.Y. FNØ2xr
The R-75 will be far better than the Grundig. As KC2GOG said, if you are planning on "upgrading" in the future, I'd go for the IC-718. You can purchase Icom equipment that has been factory reconditioned from HamAV Electronics. Right now they have the 718 for $464.95 and the R75 for $499.00.
Good buy.
Bill
ReceiverBeaver
Banned
RadX,
With a simple modification the 718 and just about all ham HF transceivers will transmit across pretty much all of their included ranges starting at around 1.6mhz and everywhere up from there.
But it will be illegal to do so. Some folks will scream their heads off advising you not to do this while others could care less. That will be a personal decision for you to make. It is clear though that tens of thousands of folks worldwide DX on 11 meters (freebanding) with little or no legal consequence. So again, to do so is up to you.
good luck
RadiationX
Oklahoma
See thats the thing all i was wanting is the R75 for recieve but then i thought well if a 718 is cheaper all i would be able to use is the 11 meter since im not a HAMer
all i seen an add where there are only doing an output power of .5w and 2w, and also 10w but 10w is llegal on 11meter
How come the R75 is so much more than
A 718 which you can talk on dosnt make any sence?
lcashmer
Your signature
kc2gog said:
1N34 diode hooked up to a real long wire is my primary radio.
I love your signature. What kind of earphone do you recommend with that?
obijohn
Basically, the reason the receivers are so expensive is simply because the dealers sell very few of them compared to transceivers. The simple law of supply and demand.
You can buy a used transceiver-such as an icom '706 for what a new receiver costs, and have similar RX performance. Plus, what others have said. IF you decide to get your amateur radio license- It will serve you well there too.
