Radio PTT/headset interface
Finlay3110
Hi there
I need help creating a custom soluton for a radio dispatch interface.
In short I do work as a Medical Event dispatcher for large events/concerts extera.
I am looking for a soluton to create a little interface box which can do the following
1. Allow me to connect a plantronics headset using QD
2. Allow an external PTT foot pedal
3. Allow me to connect a wide range of radios using a Hirose 6 pin universal connector
4. Secondary to the above I am looking for a way to make all of this work with a DM4400e base station. Ideally the rear port with a Hirose connector on the end
Is the above even possible? If anyone can help I’m sure the wider radio comuminity would appreciate as I have searched far and wide for a solution or any data on the above but can’t find it.
I have looked into using a software based solution however for my use case tbis would not be possible.
For ease I have attached the Hirose connector pin diagram aswell as a photo of the Planteonics QD with pin descriptions
I am open to using a QD to 3.5mm adapter in order to make the above easier
If anyone can help or point me in the right direction I would appreciate
nokones
Sun City West, AZ
Anything of this nature can be done and has been done in the past. The problem is finding a shop that will do it. Most of the shops that did custom work are long gone and the shops that use to do it and they're still in business will no longer do the custom work. They only want to do production work now. It's not rocket science.
PVP Communications use to do my custom work but stop about 3 years ago. Getting qualified workers was the problem.
Check with Klein Electronics, Planet Headsets, Racing Electronics, and Racing Radios. Rugged Radios has been involved with various audio systems for racing and off-road activities. They have the know how, but I'm not sure if they will take on anything custom.
merlin
DN32su
Easy enough to find such external speaker/mike setups in the wild. Some even with bluetooth.
Finlay3110
Rugged Radios RRP100 Multi Radio Interface​
Price Insights Typically $700
Unfornately that isn’t really what I’m looking for.
I will only be using one radio. I just need an interface that allows me to do all of the above. The plantronics QD cable can be swapped for a 3.5 jack (I have a QD to 3.5mm adapter)
Finlay3110
Roughly how much you reckon they would charge for such a setup?
ramal121
Lots and lots of watts
Calif Whine Country
Finlay3110
Found someone to make it however they have worded it better than I have
I think I get what you want, So tell me if Im on the right path here.
Box with 3.5mm 2pole jack for PTT switch, 3.5MM for headphones and mic. and a Female hirose as a universal connector
plus a Hirose to Motorola base station connection cable
