Radio Reference Site and Talkgroup Import Error
Jonwojcik
Linden, NJ
I have downloaded the system and sites from the Radio Reference database. I've never had an issue importing this into the G5 system, until now, after the website was updated. I'm getting an "input string was not in a correct format" error. Suggestions?
Thanks in advance
jabbeaux
Germany
Oof. I'd post that in new DB feedback thread below, so Lindsay + DB admins are aware.
And email support@unication.com, cc David Oney david@unication.com (that's @Unication_David on the forum).
Jonwojcik
Linden, NJ
Thanks for the suggestion. I just dropped it in the thread you gave me.
jabbeaux
Germany
Nice. I'd quickly edit your post to note you're using Unication's PPS to import from RR. I think you have 30mins from time of posting to edit.
That thread is for all DB feedback, and a couple scanner manufacturers can import from RR. Without explicitly stating, you're relying on the folks reading to know G5 = Unication. Good stuff, and good luck!
Jonwojcik
Linden, NJ
Ah... point taken and edited. Thanks!
David_Oney
Former Unication Tech Support
Raceland, KY
I am assuming this is an issue with the CSV import? The Orange Import Radio Reference button menu works fine from my limited testing.
Jonwojcik
Linden, NJ
Yes you are correct. The CSV import is the issue. I have honestly never used the orange import button. I'll give it a go.
Jonwojcik
Linden, NJ
Update. I opened the CSV export in excel and removed all of the "C's" from the control channels. Now the import from CSV works just fine.
