I have been playing around for a while with this and making headway. (I am a windows guy) but i have a problem.
If I do f 502.70000e6 -g 65 -o 17e3 -N 'LNA:35' -V I can see the control channel data and it shows the active voices freqs.
If I run f 502.70000e6 -g 65 -o 17e3 -N 'LNA:35' -V -T trunk.tsv ,I get the following.. And I did edit trunk.tsv to reflect the nass.tsv (nassau co talkgroups file) I created following Broadbands step by step outlined post towards the beginning of this thread. I dont understand what the error means so I cant really search it. When the cc data was up, it listed the nac as 1a0 so thats what I added to the entry in trunk.tsv. Does anyone know what this error means?
f 502.70000e6 -g 65 -o 17e3 -N 'LNA:35' -V -T nass.tsv
linux; GNU C++ version 5.3.1 20151219; Boost_105800; UHD_003.009.002-0-unknown
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.9
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gain: name: LNA range: start 0 stop 0 step 0
setting gain LNA to 35
supported sample rates 250000-2560000 step 24000
Invalid sample rate: 320000 Hz
Using Volk machine: sse4_2_64_orc
Using two-stage decimator for speed=1024000, decim=16/2 if1=64000 if2=32000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail:
pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[0], do_nocrypt[0]
Traceback (most recent call last):
File "./rx.py", line 826, in <module>
rx = rx_main()
File "./rx.py", line 751, in __init__
self.tb = p25_rx_block(self.options)
File "./rx.py", line 185, in __init__
self.open_usrp()
File "./rx.py", line 683, in open_usrp
self.__set_rx_from_osmosdr()
File "./rx.py", line 628, in __set_rx_from_osmosdr
self.__build_graph(self.src, capture_rate)
File "./rx.py", line 291, in __build_graph
self.trunk_rx = trunking.rx_ctl(frequency_set = self.change_freq, debug = self.options.verbosity, conf_file = self.options.trunk_conf_file, logfile_workers=logfile_workers)
File "/home/dave/op25/op25/gr-op25_repeater/apps/trunking.py", line 628, in __init__
self.build_config_tsv(conf_file)
File "/home/dave/op25/op25/gr-op25_repeater/apps/trunking.py", line 693, in build_config_tsv
nac = int(fields['nac'], 0)
KeyError: 'nac'
dave@dave-Aspire-5820T:~/op25/op25/gr-op25_repeater/apps$
