BlackCat94
- Joined
- Jul 13, 2010
- Messages
- 2
I was getting tired of poor reception on my Uniden Bearcat BC 142 XL on the adjacent counties channels. I live in the very corner of my own county and thusly if there's a medical incident in these other 2 counties I might feel obligated to respond if it was close.
I order a 20-176 Antenna from Radio Shack and some PL-259 coax on eBay. I put it outside about 18ft up on a pole. Grounded with the proper 8 gauge wire and a copper spike into the ground. My reception didn't improve one bit over the collapsible RS antenna I had before.
Came on here and did a bunch of searching and then decided to check stuff out with the ohm meter. Inside of coax and outside are obviously separate. The base and 3 aerials at the bottom are all connected, as is the outside (nut) of the PL-259 when connected. The inner, plus the top 3 are all continuous along with the "bulb" that they come out of. Is this all normal?
Thank you for any clues!
