Radio Shack Pro 106 Iowa Racom System
sgtmatt
New Glarus Wi
Hi Gang,
I'm trying to get my pro 106 scanner set up for monitoring the Iowa's Racom Edacs trunking network, my scanner has two settings for EDACS, Edacs Standard and Edacs narrow, Dubuque County Iowa is still on analog edacs. If someone could help me get it set up I would appreciate it
If Dubuque County Iowa is still using Analog, then just program your frequency & department in to the
( CONV ) programing settings.in your scanner. Do you know how to do that ?
RonnieUSA
Rowan County,KY (Morehead)
Hi Gang,
It is a standard system.
imbruski
Ankeny IA
Start with "premium" subscription, then choose RACOM site nearest your location download it along with the talk groups you want to listen to and you should be in business. Should you want to listen to other sites download them separately.
Bruce
shadcall
Ormond Beach, FL
Being an EDACS system make sure you put in all the frequencies in the order given for the Grant County RACOM site.
Dubuque, IA-WI Grant
01 857.46250 02 858.46250 03 859.46250 04 854.71250 05 858.71250 06 859.71250
07 856.16250c 08 856.71250
sgtmatt
New Glarus Wi
if they were to swich over to edacs digital what setting would I have to have it in
shadcall
Ormond Beach, FL
It all depends on what digital format they choose. If it's Provoice or Phase II you won't be able to monitor with your Pro 106.
