Radio Shack Pro-106 out of the box!
DLee162
Chesapeake, Virginia
How does the Pro-106 scanner come setup/programmed from Radio Shack. I have done a reset on mine and it boots up to NEW EDIT GLOB! If I press SEARCH, it scans a pretty extensive list, I can also monitor railroad, aircraft, Public Safety. Any help on the initial setup will be appreciated. I called Radio Shack, and spoke with 4 associates at 4 different stores, they all say when the radio is sold, they don't program the radio for your area, you must do that yourself.
w2xq
Burlington County, NJ
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID BIONIC Build/6.7.2-223_DBN_M4-23) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
It comes preloaded with what are now very much outdated scan lists. You must program the radio itself. Depending on what you want to listen to, you can program the radio by hand or with third-party software (all have 30-day free trials) and the RS cable. Look at the wiki and search the message threads; there are hundreds of Q&A here on RR. HTH.
shadcall
Ormond Beach, FL
Here is an easier to read manual for your scanner.
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
While there are a few software programs to help you program your scanner I strongly suggest ARC 500 by Butel. It is an easy to use program.
