Radio Shack Pro-162 Question
apx7000
This is my first post, so I apologize if it is not in the correct place. Anyway, I have a Radio Shack Pro-162 that will power on and the keypads beep but the squelch will not work. It makes no hissing sound not matter which direction it is turned. The radio is not able to pick up transmissions and I don't know how to fix it. Any help would be appreciated.
spooney
Indiana
First thing, has it ever been programmed? Second thing, press the weather (WX) button for two seconds and see if you hear a weather channel.
apx7000
Yes It has been programmed before and worked fine. Thats not the issue. I've tried the weather channels but if refuses to pick it up.
gmclam
Fair Oaks, CA
The squelch is also controlled digitally. Make sure you are in MAN or TUNE mode and the MODE is selected to FM. When the mode is CT (PL) or DC (DPL) a tone must be present to open the squelch. It sounds to me like this might be your situation.
apx7000
gmclam,
I made sure the mode is selected to FM but still no luck. I even reset it to factory settings and wiped eveything out which didn't work either. I'm thinking it is an internal problem and have no idea what component would cause this problem.
nanZor
Maybe we can narrow it down - does it actually seem to function and stop on a known active frequency, like NOAA, even though there is no sound? If it doesn't stop, then one common cause is a broken bnc center conductor wire.
If it does actually stop, but with no sound, then have you tried listening with headphones? Since speaker audio is routed through headphone jacks, it is not uncommon for the contacts to oxidize over time without any exercise once in a blue moon.
What do you listen to? Conventional, Trunked, or a mix of both? Are you accidentally in the TRUNK mode when you are scanning conventional channels? If you listen mostly to trunked, is it possible that the system itself has changed? I had one of those a long time ago, and seem to remember that if you hit the TRUNK key accidentally, you can't scan convention channels.
It was also my first introduction to the fact that when trunking, it seems like the squelch is broken producing no sound when wide open, unlike conventional channels where the squelch is operating in a classic fashion.
apx7000
hertzian,
I listen to conventional frequencies mostly and it does not stop on any active frequencies. I've tested it with local public safety frequencies, NOAA, and using a radio right next to it programmed to the same frequency. I will check the bnc connector.
Thanks for the responses
apx7000
hertzian,
Your suggestion led me to locate the problem! I found out that inside the scanner there is a component that has several contact pins on each side which were not contacting the board correctly.
Thanks again
