So I just bought a Pro-164 scanner and I need to know how I go about programming this thing to get all the local PD, EMS, and Fire channels..... Can someone please help me figure this crap out? It seems a bit involved. Thanks a bunch!
I have the same scanner, and I have no idea how to program it... I tried entering trunking infomration on the keypad, and never got it to work. I just today brought it back to Radio Shack to get reprogrammed. Won't yours program it for you?
Anyway, I am going to try the software programming soon. Just haven't hooked it up to the computer for that yet. Good luck.
Ok so I went to Radio Shack and bought the cable I need to hook it up to my computer and downloaded the Mclean County frequency pack but I dont see it on my scanner now.....
Did you use software to load the frequencies? You do need to be a premium subscriber to import from RR.
Larry
Let's start with some very basic questions;
a. Let's insure that you bought the right software. Since you mentioned you got 2 free downloads, did you get ARC300?
Yes it is ARC300
b. Which cable did you buy? The 20-546 USB cable, hopefully? Did you load the right drivers for your OS (Vista, Win7) and check the allocated COM port as described in this wiki article (all links are in blue)
The cable I bought is the 20-047?
Connecting scanners via USB - The RadioReference Wiki
c. I don't have ARC300 but I would expect that there is some sort of routine you have to do to make sure the correct COM port is selected
d. Is there a procedure in the 164 to put the radio into a PC mode?
Those are a few things that having issues with can prevent a PC from uploading to the scanner.
Best Regards...Mike
The Pro-164 will not work in Mclean County as they are on the Statewide Starcom 21 P25 Digital System.
I thought the Pro-164 was a trunking digital scanner....
