Radio Shack Pro 18
farful
ozark, missouri
I am looking for an ac adapter 5v.500amp for the Pro 18. Does anyone know who sells them? This is the external power recommended in the owners manual. Thanks guys-------
KC5EIB
Flower Mound, TX
The Pro-18 uses a MINI USB power connecton. ant MINI USB charger will work (Camers, MP3 Player, Cell Phone, ...). The Shack sells a number of adapters, for car and home, that will work with the cable that comes with the scanner or has the cable built in.
TES
America's High Plains
Seriously? So I guess you really don't want the Pro-18 to be your only scanner if you plan to listen frequently because you'd be out of luck whenever you needed to re-charge. I wonder who came up with that brilliant idea.
I suspect it was someone more familiar with the design of the Radio Shack Pro 18 than you. This post—written for the PSR 800—explains the issue quite clearly.
buddrousa
It's not a problem to me I have 30 min ext charger 3 sets of batteries as I have for my Pro-96 Pro-106. The big thing is I can not look up RR database in the field and program my 96 106 as fast as I can pull out of the Lib if I end up in a new area. Plus I can run multi configs buy taking more mem chips to test diff configs when going to new areas> That can not be done with out taking the laptop for my other handhelds. Plus I am a scanner junkie and have no children so I can have all the things I want. All scanners have things people like and do not like. One thing to remember there will never be 1 scanner that will ever make all user happy.
